Spec Check before i order...
6 Nov 2002
It's finally time to upgrade my ageing audio recording setup, so thought you guys might give this spec the once over to make sure i'm getting the best bang for buck before i take the plunge!
Items I already have are:
- Lian Li PC7 case
- ATI 4870 1gb
- 2 x 320gb Samsung HDDs
- 1 x 1TB Samsung F1 HDD
- Line 6 Toneport UX8
Items i'm ordering are:
- Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz (Nehalem) (Socket LGA1366) OEM
- OCZ Gold 6GB (3x2GB) DDR3 PC3-12800C8 (1600MHz) Tri-Channel (OCZ3G1600LV6GK)
- Gigabyte GA-EX58-UD3R Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
- Corsair H50-1 Hydro Series High-performance CPU Watercooler, LGA775/1156/1366, AM2/2+/AM3
- LG GH22NS50 22x DVD±R, 16xDVD±DL, DVD+RW x8/-RWx6 ,12xRAM SATA, Black, OEM
- 650W Corsair CMPSU-650TX, single 12V rail, energy efficient, quiet & cool, fully compatible
- Dell ST2410 24" Widescreen LCD Monitor
Is that a good setup do you reckon? Anything you think I should change?
Cheers!
Jon
