Spec check before order :)
26 Feb 2009
Norn Iron
Hi there, I've been craving some new kit for ages now and I think I'll bite the bullet and go for it.
I will keep my case, DVD drive, HDD and my Sunbeam Core Contact cooler from my rig now.
Anyone see any problems with this spec? I game at 1650x1080. Altho this may too be upgraded sometime, and I like the option to CF, hence my choice of board.
Open to suggestions to make it cheaper too!
Gskill ripjaw memory is £9 cheaper?
That's all I can think off.
Edit. Use the £9 to get the Asus P7P55D-E it has new usb3 and sata 6gb.
Thats for the inpout guys that seems like a good idea.
As for the cooler... I dont know :/ I was just kinda praying it would...
Edit// No it doesnt damnit. I though you meant would it fit the motherboard but upon checking it doesnt fit the socket either :( Damn...
Ha so it does, how strange... But the cooler clearly states (Pasted for truth!)
Titan TTC-NK85TZ Fenrir CPU Cooler (Socket 754/939/940/AM2/LGA775/LGA1366)
I dont want to be spending another small fortune on a cooler but I would like to overclock and it to be quiet as possible...any other suggestions?
Zalman quiet CPU cooler! £36
EDIT!! Wait a second, the Hardware secrets review of the titan fenrir, dated febuary 2010 says it does fit.
The other reviews dated last year at other sites say it don't.
I wonder if its received an update to make it compatible?
There is a socket 1156 bracket available for the Titan Fenrir which you need to get separately. Maybe the newer examples of the cooler come with this bracket included so it would be good to check this with OcUK first.
Revised Spec taking advantage of 2 offers, so i changed from the Sapphire to the Asus GPU and the GSkill RAM and added the zalman cooler.
All seem good?
Excellent, thanks for all your help :)
I've now become rather torn between crossfiring now or waiting...as I know the 5770 is pretty much the same as my 4870 so probably wont see much difference... Must...wait...
