Spec Check - Enough PSU Power?
19 Dec 2003
Grimsby, UK
Hi just a quick question, do you think my Tagan 580W will be sufficient enough to power the following an upgrade? Advice would be appreciated, thanks.
* New Upgrades.
* Abit IN9 32X-MAX WiFi nForce 680 (Socket 775) PCI-Express DDR2 Motherboard
*Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail
*CellShock 2GB (2 x 1GB) DDR2 PC2-8000C4 1000MHz Dual Channel Kit
*Titan Amanda TTC-NP04TZ TEC & Heatpipe Cooling Fan (Socket 775)
*EVGA GeForce 8800 GTX KO ACS3 SILENT 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
Creative Sound Blaster X-Fi Fatal1ty FPS Edition - Retail
Western Digital Raptor 150GB WD1500ADFD 10,000RPM SATA 16MB Cache - OEM
Western Digital Raptor 74GB WD740ADFD 10,000RPM SATA 16MB Cache - OEM
Akasa Eclipse 62 Aluminium Case
Tagan TG580-U15 580W ATX2.01 Easycon SLi Compliant Modular Silent PSU
hmmmm, 580W may be just about ok. However, it may be worth going for the Corsair 620W just to give you that little extra head room.
I'll never sli/crossfire, but if I was to go quad core, which would be the next ideal PSU? Would the Seasonic M12 Modular 700W Silent ATX2.0 Power Supply be sufficient?
Cheers guys added the Seasonic M12 Modular 700W Silent ATX2.0 PSU to my order, I'll mis my tagan it was very quiet, hope this is too! :p
