Put together a rig with that GPU last week. Cracking card.
Did run into a spot of trouble with an Asus Z97 motherboard and 4x4GB RAM. Crashes due to not enough system agent voltage for RAM. OcUK will likely take care of that with voltage tweaks if needed, but if you'd like a better chance of the BIOS being as close to default as possible, I would advise 2x8GB sticks. And why not go for faster speed than 1600MHz? Just curious.
I would change the SSD to a better model. That Kingston model no longer has the same speed as it did upon release. They altered its makeup. Samsung 840 EVO would be my choice. Rapid Mode in Samsung Magician will make good use of the amount of RAM your friend will have.
