Hi guys,
Just looking for a last minute check before I buy the below:
It will go with:
Thermalright Archon CPU Cooler
Samsung SpinPoint F3 1TB SATA-II 32MB Cache
5770 Crossfire
DVD rewriter drive
I think I will end up with a pretty good system as Im looking for quite an upgrade on my current spec.
CPU should make all the difference.
Is there anything you would change on what Im buying for any obvious reason - Budget is pretty maxed at current cost?
Cheers,
ash
It will go with:
5770 Crossfire
DVD rewriter drive
Cheers,
ash
