Hi all just about to take the plunge into watercooling and would like some advice from you guys.
As per my previous thread, I'll be using 2nd hand parts.
I have 2 different combinations which I'm thinking
Corsair 350D setup
2x Ax240 rads
Arc mini r2 setup
1x Ax240
1x ax360
Both setup will be using compression fittings.
As for pumps I'm still undecided on a d5 + tube res or ddc pump/res combo.
They will be cooling a 2600k @ 4.5Ghz, 2x 280x @ as high as possible
The reasons behind radiator choices is because the 350d can only take 2x 240 whereas the. Arc mini can take 1x 240 and 1x 360,and I wanted to maximise rad space where possible.
My main questions are:
Is 2x 240 enough to cool my setup? (I prefer the looks of the 350d,but don't want to limit myself because of it)
Is a ddc pump enough to power through the setup?
Corsair 350D setup
2x Ax240 rads
Arc mini r2 setup
1x Ax240
1x ax360
.The reasons behind radiator choices is because the 350d can only take 2x 240 whereas the. Arc mini can take 1x 240 and 1x 360,and I wanted to maximise rad space where possible.
