Spec check for my Ryzen upgrade
27 Aug 2004
I am looking to upgrade my current pc. I will be resusing certain parts such as the storage drives, PSU(bequiet Darkpower pro 650w ) and the Noctua NHD15S cooler. Does what I specified look ok? I already have a 2070 super to put in this build. Also I did want to get the 32gb 16 x 2 set that I have seen elsewhere, is there any advantages/disadvantages to having 4 x 8gb sticks rather that 2 x 16gb sets the cost works out to be a little bit less for the 2 x 16 gb kit
Total: £962.44 (includes shipping: £10.50)
RAM timing is different on each kit if you scroll down a bit into the blurb, the Ryzen kit is looser timings which I'm assuming is down to Ryzen being a bit fussy with memory. To be honest, I would spend a bit more on a CL16 kit, or even look at the 8pack 3200mhz and time that to 3600 CL16 which it absolutely 100% will do.
^^ The Crucial (Micron E Die) would get my vote as well.
Also swap out that paste for Thermal Grizzly Kryonaut.
You could save £50 on the motherboard by going with the Aorus Elite.
My basket at Overclockers UK:
Total: £365.47 (includes shipping: £10.50)​
Thanks for the responses guys I will take a look. I just wish it was a bit clearer on Gigabytes site as to what the differences between the versions are.
