Going to start ordering parts tonight for a quick pc upgrade.
I've noticed on the gigabyte site it says for ram voltage - 4 x 1.8V and i've selected the OCZ 4GB (2x2GB) DDR2 PC2-8500 Gold from the OcUK site which says they are 2.1 Volts.
Will the RAM work at stock settings without messing and oc'ing the motherboard?
secondly (im new to this can you tell
) would a Be Quiet! Dark Power Pro 550W ATX2.2 Modular SLi Compliant Power Supply cope with this lot ?.
only having 3 hdds, no floppy disk also the graphics are 1gb worth of Sapphire HD 4850 goodness.
1. 1 x 24-pin ATX main power connector
2. 1 x 4-pin ATX 12V power connector
3. 1 x floppy disk drive connector
4. 1 x IDE connector
5. 6 x SATA 3Gb/s connectors
6. 1 x CPU fan header
7. 2 x system fan headers
8. 1 x power fan header
9. 1 x front panel header
10. 1 x front panel audio header
11. 1 x CD In connector
12. 1 x S/PDIF In header
13. 1 x S/PDIF Out header
14. 2 x USB 2.0/1.1 headers
15. 1 x IEEE 1394a header
16. 1 x parallel port header
17. 1 x serial port header
18. 1 x power LED header
19. 1 x chassis intrusion header
) would a Be Quiet! Dark Power Pro 550W ATX2.2 Modular SLi Compliant Power Supply cope with this lot ?. only having 3 hdds, no floppy disk also the graphics are 1gb worth of Sapphire HD 4850 goodness.
