Am looking to build my First watercooled p.c. in the near future. It will all fit , I hope, in my existing Haf 932 case.
Only 'mod' (if you can call it that) I propose making to the case is to remove the roof 200 fan so that I can fit the radiator.
I am looking to cool both cpu (Q9650) & gpu (GTX 470).
Initial proposed purchases are :-
XSPC dual 750 pump/res combo. (to fit nicely in top 5 1/2 bays)
EK coolstream xt 360 radiator.(to fit where the 200 fan is)
EK Supreme HF Copper Cpu block
EK Full cover 470GTX block.
Would my proposed pump/reservoir/radiator be good enough?
Ref. the cpu block ; I note that the Supreme LT is a bit cheaper - old tech/not as good ? or is it the better option if , like me, your not bothered about seeing the water flow thru?
Also would the correct order be (1)pump/res(2)Rad(3)cpu block(4)gpu block (1) etc ?
Sorry for all the questions - all help gratefully received
