Spec Check. Need some help pls
28 May 2007
Can somone give this a once over for me. do you think it will run ok heat and power wise.
Antec NSK 1300 300 Watt psu
Athlon 64 4000+(939)
Power Colour X1950 Pro 256mb
Foxconn 6150K8MA-8EKRS
Crucial 2GB (2x1GB) PC3200 CAS3
Samsung SpinPoint 500gig sata
Plus sound card,dvd,card reader and mybe wifi
Cheers.
It should, however with all that you described in that case, you're going to have some problems fitting it all in and keeping it all cool as well.
What's the system for? What's the budget? There certainly are better components for around the same price. :)
It's for under the TV with Xp MCE and might do some gaming now and then, im only buying the case,ram and gfx card ive got everthing else and thought i put them to some use. i was going to build a conroe-L based system but got feedup with waiting.
ive got £60 for the case the gfx card is just over £70 and the ram is £88 on overclockers but i could put more to it.
got to go now and will be back later.
cheers.
Back now,
So, should this system be ok? or will a rethink be in order? i could do this to use less power
Athlon 64 4000+(939) - Athlon 64 3700+
Power Colour X1950 Pro 256mb - X1650xt 265 DDR3
Crucial 2GB (2x1GB) PC3200 CAS3 - 1gb Geil One
whats your budget mate? im sure much better performance to value could be made of this with much newer parts giving much much better performance.
Antec NSK1300 ATX Cube Case - 300W PSU £49.99
NEC AD7170S Serial ATA 18x18 DVD±RW Dual Layer ReWriter (Black) - OEM £16.99
Abit IP-95 Micro ATX (Socket 775) PCI-Express DDR2 Motherboard Abit IP-95 Micro ATX (Socket 775) PCI-Express DDR2 Motherboard £29.99
OcUK ATI Radeon X1950 Pro 256MB GDDR3 HDTV/DVI (PCI-Express) - Retail £59.99
Corsair 2GB DDR2 Value Select PC4200 Dual Channel Kit (2x1GB) (VS2GBKIT533D2) £45.99
Intel Core 2 Duo E2140 "LGA775 Conroe" 1.60GHz (800FSB) - Retail £39.99
Samsung SpinPoint T HD501LJ 500GB SATA-II 16MB Cache - OEM £53.99
Sub Total : £296.93
Shipping : £8.95
VAT : £53.70
Total : £360.58
Thanks Jonny,
just found the celerons. a 440 for £31 retail with a low profile heatsink, a motherboard for £24 plus i have a half hight x1600pro sitting at a freinds house so mybe ill build htpc instead.
Hi Pulse,
Thats a nice price for that system, but it's just for under the TV and would waisted really, dont need it to rip dvd's or do any photo editing and i'm sure the 3700+/4000+ or Celeron-L can still rip through anything thats thrown at them.
i just really need to know if the antec case and power supply will cope with this system.
Cheers.
might be pushing it just a little but i have got my x2 4200 (overclocked), 2gb ram, 2 harddrives, a very powerhungry X1900XT (overclocked) and dvd drive in my shuttle which has a 350W PSU.
