Spec Check please guys
25 Jan 2003
Weston-Super-Mare
Budget is £300 - £380, is there any way i could this better/cheaper ?
Don't need graphics as i'm sticking with my x1950 pro, also gonna stay with the Sonata case i have.
Thanks.
I'll be upgrading from an Opty146 with Asrock Dual Sata, so i'm assuming i'll see a nice performance boost ?
yeah i'd say get an e2180 and clock the nuts off it
to get the most out of it get a tuniq tower or a thermalight 120 extreme, if they'll fit that is =p
I see what you're saying but won't the difference in the L2 caches make a difference performance wise?
Could i oc the 6550 ?
