Spec Check please - may need tinkering
22 Sep 2005
Manchester
Shopping Cart (Prices in British Pounds) REFERENCE DESCRIPTION QUANTITY PRICE COST REMOVE
CP-147-AM AMD Athlon 64 3500+ Venice 90nm (Socket 939) - OEM (CP-147-AM)
£99.95 £99.95
MB-121-AS Asus A8V-E SE VIA K8T890 (Socket 939) PCI-Express Motherboard (MB-121-AS)
£47.95 £47.95
MY-005-GL GeIL 1GB (2x512MB) PC3200 Value Dual Channel Kit CAS2.5 (GE1GB3200BHDC) (MY-005-GL)
£51.95 £51.95
FG-000-AR Arctic Cooling Freezer 64 Pro CPU Cooler (Socket 754/939/940) (FG-000-AR)
£15.95 £15.95
HD-058-SE Seagate Barracuda 7200.9 NCQ 250GB ST3250824AS SATA-II 8MB Cache - OEM (HD-058-SE)
£53.95 £53.95
CA-000-AR Arctic Cooling T1 Silentium Silent Midi Tower Case - 350W Seasonic Silent PSU (CA-000-AR)
£49.95 £49.95
CD-030-NE NEC ND4570 16x16 DVD±RW Dual Layer ReWriter (Black) - OEM (CD-030-NE)
£24.95 £24.95
Subtotal £344.65
Shipping (City Link Parcel Next Day (Delivered Mon-Fri)) £10.95
VAT £62.23
Total £417.83
base unit only.
im selling him a 256MB geforce 6200, a monitor a keyboard and a mouse so dont worry about them
main use: video capturing / editing / encoding ( xbox stuff) and light gaming
Rick
The parts are all compatible and should be fine, if the person is willing to try overclocking then they might be better with the 144 Opteron for the same price but if not the 3500 Venice will be fine.
You could also change the case and PSU to the Antec SLK3800 as it is properly 400w and a good PSU but since it is a pretty light load anyway the 350w is probably more than sufficient :)
dont htink he will make it intime for the this week only offer. for the opteron
is the 144 and the 3500 the same speeds at stock ?
i know the optys are better fro OCign due to their hand selected cores etc just i dont understand the numbers and clocks for AMDs.
i was concerned about the PSU in that case but as you said it is a light load. ill see if he can stretch it to the antec case though ;)
all parts are compatible :) not bad for a 5 minute amd spec frrom an intel guy lol
