Righty, what do you guys think of this spec I've knocked up, bearing in mind it will be used mostly for document work and internet, quite a lot as a media centre type thing (although not truly a HTPC), music editing, a little Photoshop and some gaming (not bothered about playing FEAR at max or anything like that), and a little overclocking just for the sake of it! However I'd like some room to spare, so not going for absolute basics.
AMD Athlon 64 3200+ Venice
Zalman CNPS7700-CU Ultra-Quiet CPU Cooler
Asus A8N-E nForce4 Ultra
Akasa Ultra Quiet 460W Paxpower Active PFC ATX2.0 PSU
GeIL 1GB (2x512MB) PC3200 Value Dual Channel Kit
Sapphire X800 GTO² LE Dual DVI (PCI-E)
Zalman VF700-CU Quiet Copper VGA Cooler
Maxtor DiamondMax Plus 10 NCQ 250GB 6V250F0 SATA-II 16MB Cache
LG GSA-4167B DVD-RAM
The one thing I wasn't sure about is the mobo, can anyone recommend a better one for a similar price? The total budget so far for the above spec is about £400-500, is it suitable? Oh, and I've not yet decided on a case, but it might be quite expensive, I quite like the look of the new Lian Li's out soon.
