Spec......Check (please)
28 Aug 2004
I should hopefully be getting this at the end of the week. :D
Intel Core 2 Duo E6600
EVGA GeForce 7950GX2 1024MB DDR3 HDTV-DVI Dual DVI
GeIL 2GB (2x1GB) PC6400 800MHz Ultra Low Latency DDR2 Dual Channel Kit
Asus P5W DH Deluxe WiFi (Socket 775) PCI-Express DDR2 Motherboard
Seagate Barracuda 7200.10 320GB
Zalman CNPS9500-LED Aero Flower (Socket 939/754/478/775) CPU Cooler
Akasa Eclipse 62 Aluminium Case - No PSU
Akasa Eclipse 62 Thermally Advanced Side Panel
Hiper HPU-4B580 Type R 580W Modular ATX2.2 PSU - Blue
SpeedLink Ultra SL-6466 Flat Illuminated Metal Keyboard
Not to sure on the Zalman or the Hiper. :confused:
I'm not too bothered by noise, so which cools the best: Zalman 9500 or Scythe Ninja?
Is 580W enough for this setup?
Thanks for any advice.
Get the Scythe Ninja, i would recommed changing your PSU to Enermax, tagan, FSP or Seasonic. But apart from that everything looks good.
Wow thank for the fast replies.
Ok so I'll change the PSU to the:
Enermax Liberty 500W ELT500AWT ATX2.2 Modular SLI Compliant PSU. Would that be enough?
So the Scythe is cooler than the 9500? Or just better overall?
Cheers for info guys.
