Hi guys,
could you just have a quick look over the following components before i hit the buy button !? My budget is £700 and i want a decent base system that i can upgrade to a dx10 card when the prices fall.
I chose the p5b deluxe as im not sure i can wait for Nvidia 650i Ultra. Would people recomend waiting ?? as i wont be ordering these for 2 weeks. Any dates for 650i ultra yet ???
The pc will be an upgrade from my sig so i think i should see a good performance boost ! I will be running the pc at clock speeds for a month or so but will buy a better air cooler and have a go at overclocking (newbie) at some point.
Any non compatible bits there ????
Corsair HX 520W ATX2.2 Modular SLI Compliant PSU (CMPSU-520HXUK) £59.99
(£70.49)
HIS ATI Radeon X1950 Pro ICEQ 3 TURBO SILENT Heatpipe 256MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail (H195PRQT256DD-R)
£117.99
(£138.64)
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - Retail £105.99
(£124.54)
Seagate Barracuda 7200.10 250GB ST3250620AS SATA-II 16MB Cache - OEM
£49.99
(£58.74)
GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC)
£144.99
(£170.36)
Asus P5B Deluxe (Socket 775) PCI-Express DDR2 Motherboard
£104.99
(£123.36)
Sub Total : £583.94
Vat : £103.93
Total : £697.82
What do you rekon ?
Cheers
Arge
(£70.49)
£117.99
(£138.64)
(£124.54)
£49.99
(£58.74)
£144.99
(£170.36)
£104.99
(£123.36)
Sub Total : £583.94
Vat : £103.93
Total : £697.82
What do you rekon ?
Cheers
Arge
