Spec Check Please
31 Dec 2002
Hi,
Looking to build the following for general use plus some gaming. Also intend using the Dell monitor for some Xbox360 and eventually PS3 gaming. does the Dell allow pixel mapping for lower resolutions?
GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC)
Asus P5B Deluxe (Socket 775) PCI-Express DDR2 Motherboard
Dell Ultrasharp 2407WFP 24" Widescreen LCD Monitor-Midnight Grey
Intel Core 2 DUO E6400 "LGA775 Allendale" 2.13GHz (1066FSB)-Retail
BFG GeForce 7950 GT OC 512MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
Pioneer DVR-111D 16x16 DVD±RW Dual Layer ReWriter - (Beige) OEM
Seasonic S12 Energy+ 650W Silent ATX2.0 Power Supply
Akasa Mirage 62 Aluminium Case - No PSU
Samsung SpinPoint P SP2504C 250GB SATA-II 8MB Cache - OEM
Icy Dock MB-453SPF 3-Bay Internal SATA Drive Enclosure
Logitech Cordless Desktop S 510 - Black/Silver
Eisenhorn said:
Better as in faster? or better image quality? thanks
The image quality is possibly arguable but it is definitely faster in most circumstances. :)
It all looks good, you might want to consider the Corsair 620w PSU instead of the Seasonic, it is based on the same design as Seasonic but it is modular, a bit cheaper and apparantly built to even higher quality standards. You might also be better going for an after-market cooler if you want to overclock or alternatively just because it will be a bit quieter normally.
i second the guys above for the psu get the corsair 620, and for the gfx at that uber res on that monitor if you can afford i would reccomend getting the 8800gts if you can stretch to it.
