Spec Check please
Permabanned
26 Nov 2006
guildford, surrey
This will be going with XP home, plus a Dell 20 inch WS monitor 1680x1050.
Is this a good spec? Does it come with everything i need? Is the OCUK GTX any good? and will the e6300 be ok for it? Will the card fit the case and be cooled ok?
thanks
seems ok bar the value RAM.
hmm...The gigabyte board, I know my DQ6 has a RAM compatibility problem. Would be worth you finding out if the DS3 has too.
If you want to overclock, the e4300 has a 9x multiplier and should do 2.4ghz without having a fsb higher than normal e6600s ;)
Faster CPUs make FPS higher especially with that 8800GTX and CPU limits :D :D :D
