Spec check please...
  • Thread starter Thread starter tsj
  • Start date Start date
tsj
tsj
Permabanned
7 May 2004
United Kingdom
EVGA nForce 680 (Socket 775) PCI-Express DDR2 Motherboard
OEM E6600 Core 2 Duo + Arctic Cooler 7 Pro
OCZ 2GB (2 x 1GB) PC2-6400 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK)
Antec P180 Advanced Super Midi Tower Case - No PSU (Black)
Corsair HX 520W ATX2.2 Modular SLI Compliant PSU (CMPSU-520HXUK)
I already have a spare 200gb SATA Drive... and a DVD-RW Drive.. GFX i will grab a cheap priced pci-E card until i can afford something a bit better
Can you guys tell me if I forgot anything... if i should change anything.
thanks
Can someone confirm that the psu is good the for the case because ive heard that the wires need to be a little longer because the psu is at the bottom.
Also will i be able to fit a 8800 gts/gtx in here soon?
Thanks
i'd change the cooler to either a titan vanessa-l or a tuniq tower 120.
other than that it looks nice. if your wanting a 8800gtx i'd get a 600w atx 2.2 rather than 520.
Thanks
Yes, it's all fine.
masslac said:
Looks fine to me.
For a budget card, consider the 7600GT or 1950PRO. :)
Yeah mate... i was thinking of grabbing a used card from the MM for now. Will grab a better one in April/May
I'll probably go for the GTS for now. would that work with it? I'm a bit of a budget hehe :P
520W is more than fine for any of the 8800 series cards.
OP, the GTS is a superb card. You'll have no compatibility issues at all.
Ah sounds good then. :)
I've got my motherboard and OEM cpu now.
Any other reccomendations? before i order?
masslac said:
scythe ninja cooler maybe? they're fanless/silent at stock
Ill check the price of em and consider it :P
what have u got running mate
nah, the ninja isnt as good as the ones i suggested. those are the best 2, the noctua is also good. those are the top 3 coolers.
hehe... ummm i dunno which to get now...
wht about the ram... is that good enough
After considering your posts I think I'm going to order the following:
Scythe Ninja B
Corsair HX 520W
OCZ 2GB Ram
And a Sub-£100 GFX card
I just looked on google and found that the Ninja does NOT fit in a 680i board
