Spec check please!
15 Sep 2009
Sheffield
Hi guys,
im pretty sure it will, but i just wanna double check that this will all work well together -
CPU: AMD Phenom II X4 955 BE
Motherboard: Gigabyte AM3 880GMA-UD2H Rev 2.0 Sata III and USB 3.0
GPU: msi cyclone 460 gtx 768mb
RAM: 2x2gb ram
(ive got the other parts too!)
For general use, gaming, video editing, photoshop etc.
Hope you can help :)
it will be just fine, and its almost exactly the same as ive got. however, if you dont like loud computers, i would suggest an aftermarket cooler for the phenom, becuase its cooler is LOUD. probably the same kind of volume as a hardryer in the room next door
Thanks so much everyone, appreciate the help of you geniuses :)
Not sure where you are buying from as that MSI cyclone GPU isnt listed at OCUK
Yeh the 5850 is great, but i already had a gtx 460 knocking about. but appreciate your help mate, you're a huge asset on these forums, specing pc's for users 24/7! thanks :)
