Spec Check please!
5 Mar 2006
Nottingham
Hi guys,
Long-time, no see!
I've been asked to build a system for my brother-in-law, £800 budget (fairly strict) to be used for general every day tasks and some moderate gaming.
It's been a while since I've done a build so I thought it best to check! He needs everything except a keyboard and mouse.
Don't think he's got a huge amount of space in his room so I went with a smaller case (plus it looks awesome and I'm obsessed with the black/white theme :p)
YOUR BASKET
1 x Intel Core i5-3330 3.00GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £149.99
1 x Sapphire HD 7850 2048MB GDDR5 PCI-Express Graphics Card £149.99
1 x BenQ GL2460 24" Widescreen LED Slim Bezel Monitor - Black £113.99
1 x Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02050) £83.99
1 x BitFenix Prodigy Mini-ITX Cube Case - Arctic White £69.95
1 x XFX Pro 650W Core Edition '80 Plus Bronze' Power Supply £59.99
1 x MSI H61I-E35 Intel H61 (Socket 1155) DDR3 ITX Motherboard £49.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £48.95
1 x Corsair Value 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Low Voltage Dual-Channel Kit £29.98
1 x Samsung SH-224DB/BEBE 24x DVD±RW SATA ReWriter (Black) - OEM £20.99
1 x Asus Xonar DG 5.1 PCI Sound Card with built in Headphone Amp - OEM £18.95
1 x TP-Link 150Mbps Wireless PCI Express Adapter (TL-WN781ND) £10.98
Total : £824.22 (includes shipping : £13.75).
The motherboard you have picked may not support the ivybridge cpu without a bios update which can only be done with a sandybridge cpu.
Also there are no extra slots on that motherboard for your sound and network card.
If you get a larger case , mico atx size it will give you a lot more options.
Go for a 300Mbps Wireless Card. Faster speed = no lag. Lag is a killer :( Better yet, go for a £9 TP-Link Wireless USB Adapter. That way you wouldn't need a bigger case.
You don't want things poking out wasting a usb slot though.
True, but if you're not using all the USB Ports why not? :) Plus, his case he's provided doesn't have enough expansion slots for a Network Card, so if he stook with that case, he would probably need to make a decision as to whether to stick with a Graphics Card and a wired connection, or onboard graphics (which would be stupid as he wants to game too) and use the network card.
