Please could I beg a spec check ? The below will be going in to a CM 690 II advanced case, I already have GPU, PSU and drives.
Intel Core i7-4790K 4.00GHz (Devil's Canyon) Socket LGA1150 Processor - Retail £269.00
Gigabyte Z97X-UD5H Intel Z97 (Socket 1150) DDR3 ATX Motherboard £139.99 (want a gigabyte board where there is a switch to change between bios versions, been burnt recently with failed MSI bios upgrade
Corsair Hydro H80i High Performance Liquid CPU Cooler (want a good cooler that doesn't over hang RAM or GPU (bit nervous about water leaks though)).
Kingston HyperX Fury White 8GB (2x4GB) DDR3 PC3-14900C10 1866MHz Dual Channel Kit (RAM in stock thats on the motherboards compatability list.
Ta!
Ta!
