Changed my mind on the Entho Evolv build.
Can you please check the following spec.
Anything missing? Anything overkill? Is this mobo any good? Is the PSU going to be big enough.
Would like the machine to be as quiet as possible.
The Noctua D15 is not currently in stock but i assume I could use the stock cooler until this arrives.
My basket at Overclockers UK:
Total: £2,586.92
(includes shipping: £23.10)
Thanks
Whoops - left 2 psu's in there
- 1 x Samsung SM951 256GB M.2 PCI-e Gen3 8Gbps x 4 AHCI Solid State Drive (MZHPV256HDGL-00000)= £125.99
- 1 x Fractal Design Define R5 Midi Tower Case - Blackout Edition= £84.95
- 1 x Seagate 2TB 7200RPM SATA 6Gb/s 64MB Cache HDD - OEM (ST2000DM001)= £59.99
- 1 x Corsair Vengeance 16GB (4x4GB) DDR4 PC4-19200C14 2400MHz Quad Channel Kit - Black (CMK16GX4M4A2400C1= £99.95
- 1 x Noctua NH-D15 Dual Radiator Quiet CPU Cooler with two NH-A15 Fans= £77.99
- 1 x Inno3D GeForce GTX 980Ti X3 Ultra 6144MB GDDR5 PCI-Express Graphics Card (C98T3-1SDN-N5HNX)= £529.99
- 1 x Seasonic Snow Silent 750W '80 Plus Platinum' Modular Power Supply - White= £149.99
- 1 x Acer Predator X34 34" 3440x1440 IPS G-SYNC WideScreen Super-Wide ZeroFrame Curved LED Monitor= £989.99
- 1 x Gigabyte X99M Gaming 5 - Intel Core i7 5820K Six Core CPU & Motherboard Bundle ***£30 Saving***= £444.98
Total: £2,586.92
Thanks
