SPec check please
18 Nov 2002
Chester-le-street Durham.
https://www.overclockers.co.uk/inte...rocessor-retail-bx80671i76800k-cp-611-in.html
3.4 GHz Base Frequency
- 3.8 GHz Max Turboi Frequency
- 6 Cores
- 12 Threads
- 15 MB Cache
- 140W TDP
- DDR4 2400/2133 controller
i7-6800K 3.40GHz (Broadwell-E) Socket LGA2011-V3 Processor - Retail (BX80671I76800K)
£399.99
https://www.overclockers.co.uk/giga...011-ddr4-micro-atx-motherboard-mb-519-gi.html
X99M-GAMING 5 INTEL X99 (SOCKET 2011) DDR4 MICRO ATX MOTHERBOARD
Support for DDR4 2800(O.C.) / 2666(O.C.) / 2400(O.C.) / 2133 MHz memory modules
Ram voltage 1.2v
Storage 1 x M.2 PCIe connector
(Socket 3, M key, type 2242/2260/2280 SATA & PCIe x2/x1 SSD support)
£174.95
https://www.overclockers.co.uk/sams...3.0-x-4-nvme-solid-state-drive-hd-216-sa.html
MZVKV512 - 512GB Samsung SM950
M.2 (22x80) PCIe 3.0 (x4) NVMe SSD
MLC NAND
Read 2150MB/s
Write 1550MB/s
300k/100k IOPS
950 Pro 512GB M.2 PCI-e 3.0 x 4 NVMe Solid State Drive
£299.99
https://www.overclockers.co.uk/geil...el-kit-blue-led-gwb432gb2400c1-my-198-gl.html
White Dragon 32GB (4x8GB) DDR4 PC4-19200C14 2400MHz Quad Channel Kit - Blue LED (GWB432GB2400C1
2400MHz RAM Speed
CAS 14-16-16-35 Timings
1.20-1.25v VDIMM
Lifetime Warranty with OcUK
£129.95
https://www.overclockers.co.uk/inno...ddr5-pci-express-graphics-card-gx-06b-in.html
GeForce GTX 1060 Compact X1 6144MB GDDR5 PCI-Express Graphics Card
£229.99
Total so far £1,234.91
are the memory and motherboard and cpu matched please :-)
Hi
The ram, cpu and board are all compatible. You might need a bios update to support the i7 6800K depending on the version.
What is this being used for ? Is this replacing the pc in your sig ?
Hi
Hi Is going to be using it for cad electronics etc he may also get back into a bit off gaming though I don't know .
Its for my friend, he has asked me to spec up for him, His PCs is so old. and needs fast nice speed storage ie nothing slow in his pc.
Hi
can the bios be upgraded via usb socket on the motherboard ?
Not sure about the BIOS update, but why not get a 5820K instead? It's only slightly slower and will work straight out of the box, no BIOS updates required. It's also around £40 cheaper.
You can get that particular motherboard as part of a bundle with the i7 5820K. It will work straight out of the box with a Haswell-E chip.
My basket at Overclockers UK:
Total: £516.04
(includes shipping: £11.10)
What case is this going into ? Your Friend will also need a cpu cooler (If he doesn't have one already) as you don't get one with these cpu's.
HI thanks for that info will forward it
