spec check pls
17 Aug 2005
Gloucester, UK
hey all, my current system is in my sig, think its had its day tbh, play all latest games, and encode movies,. so looking for ure advice , want the upgrade to be good for quite a while, save keep spending!, i game at 1920x1080
1100 is about max, this is what i had so far :
thanks in advance
rich
ps intel only pls :)
I would suggest selling your GTX 280 and putting that money together with one of your Intel SSDs into a new ATi Card (5870 would be my suggestion)
You'll get the better performance and featureset of the 5000 series, which will certainly "be good for quite a while", and imho will see more of a return for your money than those SSDs.
(or if you can afford to wait for a bit on the graphics, you could have a look at nVidia's offering's whenever they come out)
To be fair alex, he's only got 2gb of ram which is a bit of a no no these days. And a gtx280 hardly struggles for speed. Reckon a quad core and more ram, with a ssd is not a bad option.
May have misunderstood me :), I meant it as a modification to his suggested spec, not his current rig.
There's a good set of components there, and I wouldnt change most of it, but I would personally argue that sacrificing one of the SSDs, selling off the 280 and investing in a new card to add to the rig will give a better overall performer and featureset.
Sorry. Yeah I see what you mean. Good suggestion. Think how much he could also get for his old motherboard and cpu!
