Hey guys,
Well I've been eyeing up the market at late and catching up on todays hardware etc after having not upgraded for the past 3yrs (still on P4
) and I think I've narrowed it down to the following:
As you can see, I have not included a GPU in the spec as I' waiting on the 4870x2 boards.
...Will the 4870x2 fit in the P182?
Reason for including the Q9550 is I'm hoping it to encounter a price drop rather soon. (hoping it to half which should hopefully almost cover the cost of the GPU).
Have chosen the 1000MHz (PC2-8000) Ram as I'm hoping to get a 4Ghz clockspeed on the CPU.
(Looking to purchase in September at the latest really).
Ideally looking to spend £1000 tops
Main uses being PC gaming (FPS, Strategy, MMO) however gone Quad core to future proof somewhat.
I would be grateful if you could just look over the spec to see if it's all ok or if there's anything you would advise be changed.
Don't hold back
Thanks!
Don't hold back
Thanks!
