Spec Check - Skylake Build
6 Jan 2013
Rollergirl
I'm building a system for a friend. They'll be using it for music playing/editing (via Reaper etc) and also light gaming, general use. I've left the GPU out, but he'd be opting for a 970 at the most.
I want it compact and quiet. :cool:
  • I can't see much choice for Z170 mini-ITX or micro-ATX motherboards?
  • Is the DDR4 I've picked sufficient/compatible?
  • Is the PSU enough?
  • I'm open to suggestions.
Cheers
YOUR BASKET
1 x Intel Core i5-6600K 3.9GHz (Skylake) Socket LGA1151 Processor - OEM £199.99
1 x Asus VN247H 24"Widescreen Super Narrow Bezel LED Monitor - Black £149.99
1 x Asus Z170M-Plus Intel Z170 (Socket 1151) DDR4 Micro ATX Motherboard £102.95
1 x TeamGroup Elite 16GB (2x8GB) DDR4 PC4-19200C16 2400MHz Dual Channel Kit - Black (TPKD416GM2400HC16DC01) £79.99
1 x Seagate 2TB 7200RPM SATA 6Gb/s 64MB Cache HDD - OEM (ST2000DM001) £59.99
1 x Antec P50 mATX Dual Chamber Windowed Cube Case - Black £52.99
1 x SuperFlower FX 550W '80 Plus Bronze' Power Supply - Black £49.99
1 x Kingston 120GB SSDNow V300 Drive SATA 6Gb/s 3 2.5" (7mm height) Solid State Hard Drive - (SV300S37A/120G) £47.99
1 x Asus Xonar DG 5.1 PCI Sound Card with built in Headphone Amp £24.95
1 x Cougar 200M Optical Gaming Mouse - Black £11.99
1 x Zalman ZM-K200M Multimedia/Gaming Keyboard £11.99
Total : £792.80 (includes shipping : Ex.VAT).
Err,
The SSD is not very good, Crucial BX100 or Samsung 850evo are better.
PCI soundcard on a board with no PCI slots.
You need to add a cooler.
PSU is plenty.
Err,
PSU is plenty.
I'll swap out the SSD.
Soundcard - skoolboy error!
I've got a stock Haswell heat sink and might go for an AIO if noise gets annoying.
Cheers Stulid.
I ended up installing a SF 550 plus Gold as it was fully modular which was better for such a small case.
Can I double check, this PSU would be fine for a GTX 680? The Gigabyte website says minimum is 550w but I'm hoping they've been on the heavy side and there's some headroom?
Its fine.
They say 550W to accommodate the nasty 550W PSUs that can't deliver their rated power.
The PSU you have is a true 550W PSU with the correct amperage on the 12v rail.
