The triple channel memory is for i7 systems, put a dual channel in its place for about £75 for 4gb kit.
OK cool, cheers for the help.
Any HDD gurus care to help me out on best route there?
I'd prefer not to spend hundreds on SSD, but may have to bite bullet.
If your running 7, then do what I did. Smallish SSD with a big storage drive. You can use the right click drag folders trick to move your user profiles onto the D: drive keeping C: relatively clear. If you start filling up the C drive, you can use a util like Junction Magic to move folders transparently onto the D: drive.
I'd reckon an 80GB Intel drive would be big enough. I'm using 67GB of 128GB on my C: drive, but that's with some games installed.
You still get the benefits of a snappy Windows install, with plenty of storage.
i thought about that, but its my project files which are quite big.
Say I have 10 projects bigger than 2 gb, I also have 100 projects around 100mb-300mb.
I suppose I dont use all these projects at once but moving them back and forth from storage will be a pain.
hmmf
2 things:
* The r/w speeds on the big disks are pretty good these days, especially if your machine isn't having to seek all over the disk to read program / OS files.
* Source control. Run Subversion and check things in and out![]()
Get a 1tb F3 instead of a Velociraptor. Get an i7 920 instead of the i5, and an appropriate board.
I'd go with 3x 2GB ram for now, then add more later.
I'd also get a USB dvd drive, you hardly need them these days.
why usb its 3x the price?
Coz you can use the same one for all your machines...
i do run svn, svn adds bulk not takes it away though.
If you mean only keep the projects i need on my machine by checking in, thats not really a possibility. Servicing ~100 clients means I have to jump all over the place.
If I run two disk raid1, does that make them quicker?
