Spec check
21 Aug 2005
Quick check before I order to make sure everything is the best choice:
CP-116-IN Intel Pentium 4 805 Dual Core "LGA775 Smithfield" 2.66GHz (533FSB) - Retail (CP-116-IN)
£71.95 £71.95
MB-116-AS Asus P5ND2 SLi nForce4 SLi (LGA775) PCI-Express Motherboard (MB-116-AS)
£59.95 £59.95
MY-000-PA Patriot Signature 1GB (2x512MB) PC5300 667MHz DDR2 Dual Channel Kit (PSD21G667K) (MY-000-PA)
£55.95 £55.95
CA-039-AN Antec P180 Advanced Super Midi Tower Case - No PSU (Silver) (CA-039-AN)
£59.95 £59.95
GX-026-BG BFG 3DFuzion GeForce 7600 GS 256MB DDR2 TV-Out/DVI (PCI-Express) - Retail (GX-026-BG)
£64.95 £64.95
MO-043-SA Samsung SM-920N 19" LCD Monitor - Silver/Black (MO-043-SA)
£154.95 £154.95
HS-003-SY Scythe Ninja Plus Heatpipe CPU Cooler (Socket 478, 754, 939, 940, LGA755) (HS-003-SY)
£26.95 £26.95
HD-023-SA Samsung SpinPoint P HD080HJ 80GB SATA-II 8MB Cache - OEM (HD-023-SA)
£29.95 £29.95
Subtotal £524.60
VAT £91.81
Total £616.41
Don't worry abotu size of drive as I have a 300gb drive here. Want to try and OC to at least 3.5ghz. Also getting that graphics as it is passively cooled :)
I have no idea about Pentium systems, but I can tell you that you'll want at least 2GB of RAM if its going to be a gaming machine.
EDIT: And 3.5GHz!? I hope u have some watercooling or phase??
As far as I am aware it is all compatible. What do you want the machine for though? If it is gaming I'd suggest a far better graphics card and possibly the 2gb as Global_Inferno recommends. Also do you have a PSU? That case doesn't come with one.
Will hardly ever play any games as I have an xbox 360. PC mainly for web browsing, downloading, msn etc
Oh yes, didnt notice, can you recommend one?
