Spec Check
Permabanned
16 May 2006
down the pub
Can someone check this over, i'm trying to price up a cheap system for a friend.
AMD 64 AM2 3000+ £63 With Fan
Asus M2V £64
Corsair 1GB DDR2 Value Select PC4200 Dual Channel Kit £69
BFG 3DFuzion GeForce 7300 £34
Seagate Barracuda 7200.9 120GB £44
NEC ND3550 16x16 DVD±RW Dual Layer £23
Logitech Cordless Internet Desktop Pro Black £23
Total £320
another possibility is:-
3000+ venice 939 - £55
Asus A8N5X - £52
Crucial PC3200 1gb - £37
The rest as above
New total £264 + Screen
Wouldn't it be cheaper to go s939? And with that ram (i.e. not the top speed) then you would probably lose out going to DDR2 rather than gain anything... And if budget is a real issue then wait for a month for Conroe and watch those AMD prices hit rockbottom.
The rest sounds alright, although I'm not really sure on any of them - but can't you stretch to another £10-20 and get a 250gig hdd though?
Its needed fairly soon, and the price drop of amd won't make much if any difference.
I also have to put a screen into the spec and keep the budget below £350 so can't stretch to a 250gb drive
