Spec Check!
14 Jan 2006
Hi looking at a new mobo and cpu and just wanting to see if these two are compatible together:
DFI Lanparty 875P-T SKT775
Pentium D 805 Dual Core 2.66ghz
TIA
ash_91 said:
ddr 400, although may i say i would prefer intel.
Upto you really, AMD is best bang-for-buck but as you're on a tight leash with that spec. Id say just go for what you can afford.
s-
All im after is a mobo and processor, its generally for surfing/msn/homework etc, but also a bit of light gaming, would you be able to tell me if the mobo/cpu i originally stated are compatible, if not could you recommend me a cpu for use with that board.
