spec check
24 Nov 2004
Sidcup, Kent
Anyone see any issues with the following spec, or any ways i can get the price down and have similar performance, (looking to overclock the chip as much as pos)
This is an upgrade for me from the spec in my sig, and the 300Gb sata drive i am transfering from my current system, leaving a 80Gb in there to sell it on.
Anything anyone would change, add or remove ?
Thanks for your replys in advance.
Gigabyte GA_965P_DS3 £89.99
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - OEM £99.99
GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit £169.99
HIS ATI Radeon X1900 GT ICEQ 3 SILENT Heatpipe 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-057-HT) £127.99
Zalman CNPS9500-AT Aero Flower (Socket 775) CPU Cooler £29.99
Asus TA-250 Series Midi Tower (Black) - No PSU (CA-009-AS) £21.99
Enermax Liberty 500W ELT500AWT ATX2.2 Modular SLI Compliant PSU £61.99
Subtotal £601.93
Shipping (City Link Parcel Next Day (Delivered Mon-Fri)) £10.95
VAT £107.26
Total £720.14
edit: also will this be a big performance jump for me or not much? i mostly play wow, CS:S, DAoC, so only a gaming machine really.
Depends, if you can max your games out now, then no you're not notice much difference.
New system will be faster, and you'll likely notice in newer games and in using aps, multi-tasking etc.....
Everything should be faster, but all i'm saying is, is that if thats the only games you play and you run at max detail you're not likely going to see much difference in games, apart from the extra effects the x1900 can render over the x800. Newer games will run nicely though.
