Mobo:Asus Striker Extreme nForce 680
CPU:Intel Core 2 Duo E6600
RAM:OCZ 2GB Kit (2x1GB) DDR2 800MHz/PC2-6400 CL 4-4-4-15 PLATINUM XTC with LIFETIME WARRANTY
PSU:Hiper 580W Type-R
GPU:BFG GeForce 8800 GTX OC 768MB GDDR3 HDTV/Dual DVI
HDD:Hitatchi Deskstar T7k500 320GB SATAII 7200RPM 16MB Cache
Case:Thermaltake Shark
CD/DVDSony AW-G170AB2 18xDVD±RW/RAM Dual Layer Writer
For my screen i'm unsure on what to go for got 3 in mind, there all in the same price range (£160-£205) From reviews the 20" Samsung is pretty good and one of the cheaper ones, but at work we've got DELL TFT screens and the colour on them in so crisp!
Samsung SM941BW 19" Widescreen
Samsung SM204BW 20" Widescreen
Dell E207WFP 20" Widescreen
Other than that for the above is my basic build, well still a bit iffy on the RAM as i'm not sure what to look for. I do aim to keep adding to it, RAID HDD, SLi somewhere down the line (I know i'll need to change PSU for that) and so on. So if anyone can point out if anything is wrong or i could change for the better!
