Yes its another episode of 'Check my spec please' on General Hardware forum.
My current PC spec is an A64 3400, 1gb DDR RAM with a 6800GT powering a Dell 2407 and it is now struggling to get decent framerates doing 1920x1200.
The parts I am thinking of buying are the following-
Pioneer DVR-112DBK 18x18 DVD±RW Dual Layer ReWriter - (Black) OEM
Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail
Crucial Ballistix 2GB (2x1GB) DDR2 PC2-5300C3 667MHz Dual Channel Kit x2
Akasa TIM Clean CPU & Heatsink Cleaner
Corsair HX 620W ATX2.2 Modular SLI Compliant PSU
Western Digital Caviar SE16 500GB 5000AAKS SATA-II 16MB Cache - OEM
EVGA GeForce 8800 GTX ACS3 SILENT 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
Tuniq Tower 120 CPU Cooler
Scythe S-FLEX 1200RPM Ultra Quiet 120mm Fan - 3/4 pin x5
Silverstone TJ09B-W (Black)
Asus Commando Intel 965 (Socket 775) PCI-Express DDR2 Motherboard
Total Cost £1612.49
+ a Seagate 320gb 7200.10 hard drive I currently use.
But before I go ahead and buy this in the middle of the week, theres a few odd ends I would like to tie up. The cpu/motherboard/RAM is pretty much set in stone as I did quite a lot of research into them.
My first concern is the Corsair 620W PSU, do I really need the 620W model for my spec? I plan to overclock the C2D6600 to 3.6ghz if possible. Should I drop it down to the 520W model?
The 5x 120mm fans was originally going to be the Noctua ones but people are saying they have poor air pressure making them a poor choice for use with heatsinks. I plan to use 2 of the fans to replace the Tuniq fan and the 8800GTX fan and use the other 3 as case fan on the TJ-09. Are the Scythes good fans or should I change back to the Noctuas?
Also the Scythe S-Flex fans come with a molex to 3pin mobo connector, does using this adapter undervolt the fan so it spins at lower RPM? As I dont want the fans spinning at full whack if its not needed and will need to consider a fan controller if it doesnt undervolt.
I will be using the 320gb seagate as a primary drive (3 partitions, dual booting XP with Vista and 3rd partition for files) which I assume should be fine? As I never used partitions before.
I dont normally upgrade PC's, just build a new one every 3 years hence I want it to last at least 3 years just like this current PC has.
Cheers
Total Cost £1612.49
Cheers
