- 28 Mar 2005
- Reading
Hi,
It's taken me a while of research but I am pretty much there regarding my upgrade to C2D. I only need the motherboard, ram, CPU and graphics, and have come up with this spec.
Plan to overclock, and a balance between gaming, and graphic design use is needed.
Asus P5K-E WiFi Intel P35 (Socket 775) PCI-Express DDR2 Motherboard
Intel Core 2 Duo E6750 "LGA775 Conroe" 2.66GHz (1333FSB) - Retail
Crucial Ballistix 2GB (2x1GB) DDR2 PC2-6400C4 800MHz Dual Channel Kit (BL2KIT12864AA804)
BFG GeForce 8800 GTS OC 320MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
Couple of things though:
1) I like the look of this board, but am still undecided between these 3: Asus P5K IP35-E (above), the Abit IP35 Pro, and the Gigabyte GAP35 DS4. Seems much of a muchness to me really, so any thoughts would be helpful. I know there is a bit of a price difference, but I don't mind spending a bit more.
2) Would I need to upgrade my cooler or would my XP120 fit (as in the sig). If an upgrade is best, which cooler would people recommend?
3) Would my PSU be sufficient with this platform (see sig). I don't really want to have to upgrade this again if I can help it - at least for now.
4) Was and still am tempted to get a x1950pro, as they are significantly cheaper than the card chosen here. The idea being to tide me over for 6 months until the next GPU chipsets come out. Any thoughts on this?
I'm sure when I checked last night, the Balistix RAM above was £90! Seems like a real bargain now.
Thanks
Bornslippy
Thanks
Bornslippy
