Spec check
3 Oct 2005
So my PSU went pop and took the MB with it leaving me in need of a new PC. I don't really have a maximum budget, but I also don't want to spend any more than I have to.
I wont be OCing and just want something that will cope with games @ 1680x1050 (will be doing work etc on it as well but nothing that is going to push it). Seriously tempted by the bits listed below and would appreciate opinions:
Leadtek GeForce 8800 GTS 640MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail (£223.24)
Lian Li PC-A16B Aluminium Full-Tower - Black (£93.99)
Western Digital Caviar SE16 320GB SATA-II 16MB Cache - OEM (WD3200AAKS) (£51.69)
NEC AD7170S Serial ATA 18x18 DVD±RW Dual Layer ReWriter (Black) - OEM (£18.79)
Corsair HX 520W ATX2.2 Modular SLI Compliant PSU (CMPSU-520HXUK) (£68.14)
Intel Core 2 Duo E6750 "LGA775 Conroe" 2.66GHz (1333FSB) - Retail (£125.71)
Gigabyte GA_P35_DS3P (Socket 775) PCI-Express DDR2 Motherboard (£88.11)
2x OCZ 2GB (2 x 1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK) (£86.92)
Sub Total : £643.91
Shipping : £12.95
VAT : £114.95
Total : £771.81
Excellent setup, cannot fault it.
That's the sort of reply I was hoping for, thanks :D
A few other threads have raised a question tho - I'm currently running XP Pro and was going to stick with it, but will I get the full benefit of the 4GB RAM or should I be considering the switch to Vista?
You'll get most of it using a 32Bit operating system. I know a lot of people saying "you MUST switch to 64bit" but it's really not the case and only loosing 500mb of RAM whilst your on a 32bit OS from 4GB is not a massive amount and you wouldn't notice the difference with or without it. So I'd just recommend staying with XP Pro for the moment, maybe wait for Vista Service Pack 1 and then think about switching and if you want too.
