Spec Check?
28 Dec 2002
UK
Can anyone spot any problems with this spec, compatibility wise?
Shuttle SD30G2 Barebone - Silver
Intel Core 2 Duo E6600
Corsair 2GB DDR2 Value Select PC5300
160GB Seagate Barracuda SATA
Sapphire Radeon 2600 Pro 512MB
Samsung SH-S203 SATA Dual Layer DVD Writer
Cheers. Chris.
That should all be fine, if it were a 2900 then Mr Impaler would be entirely right, while Shuttle PSUs are good for their rated wattages I think even they would struggle with a 2900pro at 250w. A 2600 should be ok but I probably wouldn't try upgrading to anything more than mid-range graphics cards at any point though. :)
