Spec check
24 Sep 2005
Stoke
Intel Core 2 Duo E6750 "LGA775 Conroe" 2.66GHz (1333FSB) - Retail
Abit IP35 Pro (Socket 775) PCI-Express DDR2 Motherboard
GeIL 2GB (2x1GB) PC2-6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket LGA775)
Any obvious problems? Does the cooler fit on the board? RAM compatibility OK? One question though, will this board require sata drivers? I just want to plug and play, especially as i don't own a floppy or USB stick. :)
it should all fit, if you are willing to OC, get the e2180 instead and OC to 3+GHz with that MB.
i didnt need sata drivers when i installed xp64 onto that MB
The thing is, i'm planning to overclock but not in the near future. the begining of the year is always really busy for me. So i need some speed at stock.
Good news on not needing drivers. :)
