Spec Check :)
22 Mar 2008
I'm thinking of selling my large desktop at the moment with moving around so much at the moment and want make a micro atx system. Not particularly looking to overclock. I do want to use the Silverstone Sugo case.
It will only be used for gaming and the odd bit of uni work (attention permitting). Also on a budget of around £650 which is just over what my current system will sell for!
FYI I will also be whacking my existing raptor in it :)
Kind of picked out the components below but any criticism welcome, I'm sure I must have mucked up somewhere!
I think you would be better off keeping the Intel CPU and finding a suitable mobo but its up to you. At the very least it will keep the temperatures down as Intels 45nm CPUs run significantly cooler.
If you want to save some money then i would swap the noctua back for the sharkroons as there just as good TBH, if you want silence then go for the 1000 versions of the sharkroons
