Spec check
29 Jan 2004
Earth
Spec check please
  • Samsung SpinPoint F1 HD103UJ 1TB Hard Drive SATAII 32MB Cache - OEM
  • Optiarc AD-7200S 20X DVD±RW/DL/RAM Internal SATA Bare Black Drive - OEM
  • Intel Core 2 Quad Q6600 G0 Stepping (2.4GHz 1066MHz) Socket 775 L2 8MB Cache (2x4MB (4MB per core pair) Retail Boxed Processor
  • Coolermaster Elite 330 Black Case With CM eXtreme Power 460W PSU
  • Asus P5KPL-AM iG31 Socket 775 onboard VGA 8 channel audio mATX Motherboard
  • OCZ 4GB (2x2GB) DDR2 800Mhz/PC2-6400 GOLD XTC Memory Kit CL5(5-5-5-18)
  • Arctic Cooling AC-FRZ-7P Freezer 7 Pro Socket 775 Processor Cooler
= Base
How does it all look? I haven't built a comp for a few years:o
I assume all SATA 2 cables are compatible with SATA1 drives etc?
Thanks
Without knowing what you are going to be using the Computer for it is hard to comment. You've only got on-board graphics which will suck big time for gaming (even minesweeper :D), but oodles of processing power with four cores...
Graphics are not an issue! Just the other stuff needs to be good :)
Sorry I was asking whether all the stuff is compatible or not, I take it, it is :p
Cheers :D
well even if your just using your PC for desktop work its a really good idea to get a graphics card even if its cheap anything is better than on board graphics, 9400Gt something like that £30-£40
but yeah everything else is all good
for desktop work you could save some money with a dual core instead of a quad. And if it will be used for gaming def get a graphics card as onboard is just poor compared to even a cheap card. Also for PSU a modular is def the way to go as it helps clean up cables in your case giving better air flow and therefore temps :)
