spec check
5 Jul 2009
DONcaster
would this do for a htpc/gamin rig
antec fusion remote black
asus maximus II gene
core 2 quad oc'd of course(not sure which yet)
coolermaster m 800w psu
2x ati hd 4890
2x 4gb kingston hyperx (2x2gb)
lg bdrom
windows 7 64bit (not sure which edition)
3x 500gb 2.5 hdd
64gb ssd
It's a low profile HTPC case as far as i'm aware.
So it won't take the PSU or the card, both are too tall.
dunno if that gfx card will fit, depends on how long it is, if the cards the standard size gfx your ok.
this image will give you an idea. MicroATX/Embedded ATX (244x244mm)
http://i29.tinypic.com/2j31bpx.jpg
you can only mount 2hds in the hd cage. but you could buy a 3.5" to 2x 2.5" bay convert.
just google 3.5" Bay to Dual 2.5" SATA HD
