Spec check
17 Aug 2010
London
This is just a little spec check for me to find out if I can make a good decent spec. I'm not getting this build but when I do it will be around £800.
the build:
Uploaded with ImageShack.us
i would probably change the case to asgard but thats me the Be Quiet! E7 600w should run that system
edit:didnt realise you picked the 965
I will be making a build next year so i just anted to check after a lot of research if I could play my cards right and make an awesome spec. The word overclock makes me shiver so no I wont eb overclocking.
Another thought, AMD & Intel are due to launch there new range Of cpu's in the next few months! :)
I have a natural hatred of matx motherboards.
for me, unless you really need one for a htpc or similar small case, you just never know when you might need more expansion slots, also if you have a massive dual slot gpu the sata ports my get covered.
wen you read up more about parts you will start to tinker with
your build. a certain part you have chosen is suddenly being
rivaled by a new release in its area with slighty better performance
or price, then you go for that.
90% of wot you have chosen now will probably be changed by the
time you build next year.
you will never truely no wot your getting until the second its charged to your credit card :)
