Spec Check
23 Aug 2010
Hey, I've been wanting to upgrade my PC for a while, then it broke, so I'm practically building a new one from scratch.
I currently have:
a 500GB Hard Drive (Got my OS's on it etc)
A 600W Corsair PSU
some CD drive
The parts I'm thinking about getting are:
http://www.overclockers.co.uk/showproduct.php?prodid=CP-366-IN
http://www.overclockers.co.uk/showproduct.php?prodid=MB-340-GI
http://www.overclockers.co.uk/showproduct.php?prodid=GX-270-SP
http://www.overclockers.co.uk/showproduct.php?prodid=CA-161-AN
http://www.overclockers.co.uk/showproduct.php?prodid=MY-203-CS
Anyone know of any reason these parts wouldn't work well together?
Any suggestions on better choices to replace any of these is also welcome.
Thanks
OP you'll very likely need to reinstall your Operating System(s).
If they're OEM versions of Windows they may not work with a new motherboard as they're tied to the motherboard they were originally installed on.
