Spec Check
6 Jul 2006
England, Stafford
Hi guy i was wondering if some one could help me with my spec, so far i have
Intel Core i5-2400 3.10GHz (Sandybridge) Socket LGA1155 Processor - Retail £143.99
OcUK GeForce GTX 560 1024MB GDDR5 PCI-Express Graphics Card £137.99
Gigabyte H61M-D2 Intel H61 Chipset (Socket 1155) DDR3 Motherboard **B3 REVISION** £54.98
OCZ ModXStream Pro 500w Silent SLI Certified Modular Power Supply £49.99
Antec 100 One Hundred Ultimate Gaming Case - Black £44.99
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £39.98
OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Dual Channel Kit (OCZ3G1333LV4GK) £23.99
LG GH22NS70 22x DVD±RW SATA ReWriter (Black) - OEM £16.99
total £512.90
my budget is 550 max tho would rather less looking for bang for buck
the computer will be used for games, i have dell 24in screen which has a res of 1920 x 1200
i already have the os and mouse and keyboard, i may also be using this computer for flight simulator that why i choose the i5 as i now it loves quad cores
please feel free to chop and change this is just what i put together as a start , also i will not be overclocking :)
thankyou
got an overclockable processor and motherboard within budget:
YOUR BASKET
1 x Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £169.99
1 x MSI GeForce GTX 460 HAWK "Super-OC" 1024MB GDDR5 PCI-Express Graphics Card £134.99
1 x Asus P8P67 LE Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) ** B3 REVISION ** £68.98
1 x Zalman Z9 Plus Tower Case with Fan Controller - Black £44.99
1 x BeQuiet Pure Power L7 530W '80 Plus' Power Supply £44.99
1 x Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST3500413AS) £28.99
1 x Kingston HyperX Blu 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9AD3B1K2/4G) £25.99
1 x Sony Optiarc AD-5260S 24x DVD±RW SATA ReWriter (Black) - OEM £15.98
Total : £549.90 (includes shipping : £12.50).
you should get 4Ghz on the standard cooler quite happily, maybe more (anandtech got 4.4Ghz on the standard cooler)
ive changed the graphics card to the GTX460 with a good aftermarket cooler because the GTX 560 is just an overclocked 460. with this GTX 460 you can happily go beyond standard 560 speeds of 822Mhz, quite a few can reach over 1000Mhz.
if i can find the review that said this i'll link it here
*edit*
here it is:
http://www.anandtech.com/show/4135/
hi ya reaper thx so much for the spec is there any reason not to get the OCZ ModXStream Pro 500w Silent SLI Certified Modular Power Supply £49.99 over the BeQuiet Pure Power L7 530W '80 Plus' Power Supply £44.99 as it is modular
