Spec Check.
16 Oct 2003
West Sussex
I've already pulled the trigger on these items but think buyers remorse has set in and not sure whether the spec is good or not now! Is there anything you think should be changed added at all? I think i have everything i need!
I7 4770k, Gigabyte Z87x-SLI mobo, G.skill tridentx 16gb 2400mhz (2x8gb), nzxt x60 cooler, corsair air 540 case, seasonic m12II evo 850w psu.
240gb sandisk extreme ssd, 60gb ocz agility 3, 2tb 7200 hdd & gigabyte 7970 windforce 3 ghz all from old pc.
What is the pc for ?
I would have gone for a Z97 board over a Z87.
If you are just gaming then 8GB is fine.
I would have gone for the Corsair H105 as a cheaper option.
Oooops forgot to add that in! have updated 1st post.
Main use is gaming with some photo/video processing thrown in, main reason for the z87 was it was cheap. £65 on the MM
Then that is a good buy :) If you don't plan on going crossfire you could have gone for a 550W/650W psu.
