spec check
1 Aug 2014
york
Going with this PSU will cover you for future Xfire/SLI
YOUR BASKET
1 x Seasonic M12II EVO Edition 850W '80 Plus Bronze' Fully Modular Power Supply £79.99
Total : £79.99 (includes shipping : ).
Bit more of a blingy PSU (leadex)
YOUR BASKET
1 x SuperFlower Leadex GOLD 850W Fully Modular "80 Plus Gold" Power Supply - Black £95.99
Total : £95.99 (includes shipping : ).
Also you might want to wait until next month/month after and see what the 800 series from nvidia have to offer, though you can't ignore that free RAM special offer!
YOUR BASKET
YOUR BASKET
is the psu i selected fully modular?
would 850w cover two 290xs?
edit: the psu i picked is leadex also, what do you mean by blingy mate?
also random question but when u buy ssds do they come with the cables needed to fit them?
Yes 850W is enough for 2 x 290X gpu's. I would suggest dropping down to a 290 as the 290x doesn't give you a whole lot more for the money.
Also check out the EVGA Supernova G2 850W psu instead. It has a longer warranty than the Leadex. The EVGA doesn't have the LED connectors, but they are virtually the same internally as they are both built by Superflower and based on the Leadex platform.
The last SSD I bought just had the bare drive. You should get enough SATA cables with the Motherboard though. They normally give you at least two.
think a 290 would handle 1440p at decent frame rates playing games like bf4/dayz/cs:go/arma/crisis 3 etc?
if so i'll get a 290
