Spec Check
25 Sep 2011
Northern Ireland
Hey guys, building a new PC and I've created a build but before I buy everything I'd really appreciate if you could have a look over it and suggest any recommendations or problems with the components I have selected.
Also, what cheap optical drive would you suggest?
Thanks in advance!
YOUR BASKET
1 x MSI GeForce GTX 970 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card £281.99
1 x Intel Core i5-4690K 3.50GHz (Devil's Canyon) Socket LGA1150 Processor - Retail £191.99
1 x Phanteks Enthoo Luxe Full Tower Case - Black £119.99
1 x BenQ GL2450HM 24" Widescreen LED Monitor - Black £115.99
1 x Corsair RM Series RM 750 '80+ Gold' 750W Power Supply (CP-9020055-UK) £109.99
1 x Gigabyte Z97X-Gaming 5 Intel Z97 (Socket 1150) DDR3 ATX Motherboard £109.99
1 x Crucial MX100 256GB SATA 2.5” 7mm SSD + 9.5mm Adapter (CT256MX100SSD1) £79.99
1 x Corsair Vengeance 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C9) £71.99
1 x Western Digital Caviar Blue 1TB SATA 6Gb/s 64MB Cache WD10EZEX - OEM ** Single Platter ** HDD £46.99
1 x Cooler Master Hyper 212 Evo CPU Cooler £24.97
Total : £1,178.00 (includes shipping : £20.10).
Thanks for the quick reply, regarding that PSU and reading the customer review, do you have any idea if the cables would be long enough for my case?
Just get an extension cable to be on the safe side. The only one you might have issues with is the cpu (EPS) cable, as it will need to reach behind the Motherboard and up to the socket.
YOUR BASKET
1 x NZXT 8-Pin (EPS12V) Black Sleeved 25cm Extension Cable - CB-8P (CB-8P) £3.49
Total : £5.77 (includes shipping : £1.90).
The Graphics card cables are listed as 550mm and the 24 pin is 540mm so they should reach ok. See link below for source.
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story2&reid=370
Ok, I'll make sure to get the extension.
Does anybody have any suggestions of a cheap but reliable optical drive?
