Can i have a spec check please.
My basket at Overclockers UK:
- 1 x Asus ROG Crosshair VII Hero AMD X470 (Socket AM4) DDR4 ATX Motherboard= £239.99
- 1 x AMD Ryzen 7 Eight Core 2700X 4.35GHz (Socket AM4) Processor - Retail= £329.99
- 1 x Arctic Silver 5 Thermal Compound (3.5g)= £6.49
- 1 x EVGA GeForce RTX 2070 XC Ultra 8192MB PCI-Express Graphics Card= £539.99
- 1 x Corsair HXi Series HX750i 750W '80 Plus Platinum Digital Modular Power Supply (CP-9020072-UK)= £174.95
- 1 x G.Skill Trident Z RGB 16GB (2x8GB) DDR4 PC4-25600C14 3200MHz Dual Channel Kit (F4-3200C14D-16GTZR)= £199.99
- 1 x be quiet! Dark Base Pro 900 Rev.2 Full Tower Gaming Case - Orange= £249.95
- 1 x Corsair Lighting Node Pro, RGB Lighting Controller with Individually Addressable RGB LED Strips= £51.95
- 2 x MDPC-X Pre-Cut Shrink Tubes 4:1 Small - Dark Grey, 50pcs= £4.99
- 5 x MDPC-X Sleeve XTC - Papaya Orange, 1 Metre= £1.19
- 1 x Corsair Commander PRO RGB LED Controller + Fan Hub - Black= £64.99
- 1 x Corsair LL120 RGB, 120mm Dual Light Loop RGB LED PWM Fan, 3 Fan Pack with Lighting Node PRO= £89.99
- 1 x Corsair LL140 RGB, 140mm Dual Light Loop RGB LED PWM Fan= £29.99
- 1 x EK Water Blocks EK-Vector RTX 2080 RGB Founders Edition Water Block - Nickel + Plexi= £129.95
- 1 x EK Water Blocks EK-Vector RTX 2080 / 2080 Ti Founders Edition Backplate - Black= £34.99
- 1 x EK Water Blocks EK-FB ASUS C6H Crosshair VI RGB Monoblock - Nickel= £119.99
- 1 x EK Water Blocks EK-CoolStream CE 420 (Triple) Radiator= £96.95
- 1 x EK Water Blocks EK-AF Ball Valve (10mm) G14 - Black= £14.99
- 2 x EK Water Blocks EK-AF Pass-Through G1/4 - Black= £4.99
- 1 x EK Water Blocks EK-UNI Pump Bracket (140mm FAN) Vertical= £14.99
- 4 x EK Water Blocks EK-HD PETG Tube 12/16mm 500mm (2pcs)= £6.95
- 1 x Bitspower Hard Tube Silicone Bending for ID 12MM - 1M= £4.99
- 1 x EK Water Blocks EK-HD Tube Reamer= £8.99
- 1 x EK Water Blocks EK-XRES 140 Revo D5 RGB (stand-alone)= £82.99
- 2 x EK Water Blocks EK-AF T-Splitter 3F G1/4 - Black= £7.19
- 2 x EK Water Blocks EK-CSQ Plug G1/4 (for EK-Badge) - Black= £3.49
- 2 x EK Water Blocks EK-AF Extender 6mm M-M G1/4 - Black= £2.99
- 2 x EK Water Blocks EK-AF Extender Rotary M-M G1/4 - Black= £4.99
- 15 x EK Water Blocks EK-HDC Fitting 16mm G1/4 - Elox Black= £6.95
- 1 x EK Water Blocks EK-AF Extender Rotary M-F G1/4 - Black= £4.99
- 2 x EK Water Blocks EK-AF Extender 8mm M-F G1/4 - Black= £2.99
- 5 x OcUK Tech Labs G1/4" Black 45 Degree Rotary Adapter= £3.95
- 5 x EK Water Blocks EK-AF Angled 2 × 45 Degrees G1 / 4 inch - Black= £8.99
- 4 x EK Water Blocks EK-AF Angled 90 Degrees G1 / 4 inch - Black= £6.95
- 5 x MDPC-X Sleeve XTC - Carbon BTI, 1 Metre= £1.19
- 1 x EK Water Blocks EK-CryoFuel Solid Fire Orange 1 Litre Premix Fluid= £14.99
Total: £2,829.29 (includes shipping: £22.50)
