Hi all,
Looking to get a laptop for 3d modelling and general work. Something to take to my local backspace etc.
Found the below spec laptop on the bay from a computer refurbishment store and wanted to know if it's ok, price is around the £550 mark.
Thanks, J.
Thanks, J.
CPU I7-6700HQ (2.6GHZ-3.5GHZ, 45W)
Motherboard EUROCOM Sky GM5 / Intel HM170 (Skylake PCH-H)
2xPCI Express x1, 1xPCI Express x16
GPU Nvidia Geforce GTX 970M 6GB GDDR5, 1280 shadars core@1037MHZ, GDDR5@1250MHZ, 192-bit bus
RAM Hyper X 2x8GB DDR4@2133MHZ
4 banks of memory available, two at each side of the motherboard
Storage HDD : 1 TB HDD
SSD: 480GB Sandisk SSD
M.2: 2 slots, 2xNVMe PCIe M.2 SSD, 1xSata
LCD Panel In review: 1080p 15.6", LG LP156WF6-SPB1, IPS, 30-pin eDP
Weight / Dimensions ~2.5kg / 5.51 lbs
385 x 271 x 25 mm
15.4" x 10.84" x 1.0"
(w x d x h)
Keyboard white backlit, 6 levels including off
Connection Ports right side: 2xUSB 3.0, Kensington Lock, microphone/headphones/S/PDIF, ethernet, 6-in-1 card reader, SIM card slot,
Left: 2xmini DP 1.2, 1xUSB 3.0 (powered), 1xHDMI 1.4
Rear: USB 3.0 combo port, power-in
Camera 1080p, 30FPS camera
WiFi / Ethernet WiFi: Killer Wireless-n/a/ac 1535 Wireless Network Adapter
Ethernet: RealTek Semiconductor RTL8168/8111 PCI-E Gigabit Ethernet NIC
Speakers 2.0 "Onkyo" speakers above the keyboard surface
Battery 4 cell, 62Wh
Bios / EC version (test unit) 1.05.16 /
Extra features Embedded TPM 2.0
