First post and its a request for help with, surprise surprise, a spec, its not like you get enough of those already.
I know a bit about PC's but hardware is defiantly not a speciality so I've been reading around forums, and different shops trying to choose what I want. The main thing I've learned is I can't make up my mind when it gets down to the specifics.
I'm actually planning on buying this in January when I should have some money but that's not far away and I'm excited about building a machine from scratch for the first time. (well 2nd if a shuttle barebones kit counts).
I'm trying to build a fast gaming machine, and also trying to stick to a budget of £1000'ish though that doesn't include the OS. Anyway as I said its the specifics of what to get that I'm after help with as for example an 8800GTX card varies in price between manufacturers and I have no clue which is the best, or the best in budget anyway. I'm sure you know what I mean.
Hard Drives - Id like fast & quiet, Minimum size would be 50+ gig. Most of my data sits on another machine so doesn't need to be a huge disk. Not worried about RAID
Memory - 2gig fast good quality
Graphics - A single 8800GTX card for now. I plan on buying a 2nd in about 6 months and run them in SLI.
PSU - Enough to run this in SLI when I get the 2nd card, I don't want to skimp on this.
Processor - Intel Core 2 Duo E6600 would be nice if it can be in the budget.
Motherboard - Capable of supporting 2 8800GTX cards in SLI. Needs a reasonable integrated sound card. Wireless NIC would be nice
Case - Really have no idea here, I'm more keen on a good case no matter what it looks like. But looking nice would be a bonus.
Cooling - ????????
I'm planning to reuse keyboard, mouse, speakers and a DVD drive from my current machine and if the above doesnt have a wireless NIC then I have a PCI one I can use. So I think the above is everything I need...
though im probably wrong
Any help appreciated.
Cooling - ????????
He spent a few quid more than me, but I went with a RAID array, and a bigger PSU/more expensive memory/aftermarket heatsink for overclocking instead.
You could try a Samsung Spinpoint or a WD Caviar SE16 series if noise is a big issue, which have reasonable performance - and you really notice HD performance very very little as a gamer.
