Spec for 1k.
26 Dec 2004
Sweatshop.
No case.
No Monitors.
No Keyboard.
No Mouse.
No Speakers.
Just internals :)
1k, for gaming!
-Thankyou. Something that would run, UT3 Nicely, if possible!
Also if you can spec me a HSF, and any other cooling, i have a pci card fan, and also some akasa ambers. and a Akasa Eclipse case :)
HDD wise i have two IDE's that make up 1/2 TB, so a raptor?
Software wise, i need Vista too in there :)
paul_64l said:
do u need optical drives if you do what colour m8
erm would i need two? if so black :) my current one is playing games with me, think its on its way out.
one might do it though?
if you want to save money you can drop to 2gb of ram, drop the sound card as onboard works, change cpu to a cheaper one but these are elegedly all gonna be good stepping if you are an overclocker
paul_64l said:
yeah, have you looked on mm for parts there can be a good saving there m8
prefer all new stuff, i can always transfer stuff outta this machine :)
sound cards etc not performance stuff.
forgot to add a 520w psu would be good enough i speced that as it will be more future proof for the sake of a few quid. nobody knows really to be more sure get this m8
you could add more ram later if you wanted
Ultra is a waste of money, got you quad core, or you could probably get core 2 duo and 4gig of ram, your choice tbh.
Intel Core 2 Quad Pro Q6600 "LGA775 Kentsfield" 2.40GHz (1066FSB) - Retail - £199.99 (£234.99)
Noctua NH-U12F (Socket LGA775/754/939/940/AM2) Heatsink - £32.99 (£38.76)
Corsair HX 620W ATX2.2 Modular SLI Compliant PSU (CMPSU-620HXUK) - £74.99 (£88.11)
Samsung SH-S183ABEBN 18x18 DVD±RW Dual Layer Serial ATA ReWriter (Black) - OEM - £16.50 (£19.39)
Western Digital Caviar SE16 500GB 5000AAKS SATA-II 16MB Cache - OEM - £52.99 (£62.26)
Leadtek GeForce 8800 GTX 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail - £299.99 (£352.49)
GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) - £63.99 (£75.19)
Gigabyte GA_P35_DS4 (Socket 775) PCI-Express DDR2 Motherboard - £94.99 (£111.61)
Sub Total : £836.43
Shipping : £9.95
VAT : £148.12
Total : £994.50
For gaming i reckon its better to get 4GB of RAM than a Quad Core with a budget of 1k seeing as RAM is so cheap, so something like a high end duel core, 4gb RAM & a GTX.
